It is currently Sat Aug 16, 2025 10:58 am
 Post subject: Spraying shellac
PostPosted: Wed Mar 03, 2010 12:09 pm
Last Name: Schreiner
City: Miami
State: FL
Zip/Postal Code: 33183
I am set up to spray lacquer and I always brush on shellac as a sealer with final results that I am quite happy with. I would like to avoid having to level sand the brush marks before I lacquer so I thought I would try to spray (not brush) the shellac instead ( I don't want to use any other sealer). Does anyone have a cut recommendation or any other thoughts on this subject? I will probably use a Prevail sprayer to experiment with if no one responds. Thanks...
Michael
 Post subject: Re: Spraying shellac
PostPosted: Wed Mar 03, 2010 12:12 pm
I use a 2 lb cut of super blond flake shellac cut with DA for sealing.
tim...
PostPosted: Wed Mar 03, 2010 12:15 pm
I've been using shellac as sealer on tops for many years. I wipe it on with a paper towel followed by a once over with synthetic steel wool about 45 minutes later. Quick and easy and I don't have to clean a spray gun.
Jimmy Caldwell
PostPosted: Wed Mar 03, 2010 1:21 pm
First name: Kent
Last Name: Bailey
City: Florissant
State: Colorado
Zip/Postal Code: 80816
I'm probably going to get the 3rd. degree....but I use Zinsser Bulls Eye Shellac (clear) in a spray can from my hardware store. I've used this product on some of my carved wood projects as a sealer coat to a poly finish and used it (reluctantly at first) on my last 3 builds with lacquer and worked just fine. I also liked the convenience of quick coating areas like the top before taping bindings and recoating small resanded areas and not having to mix or clean up my sprayer for small or quick applications.
There is NO control of spray thickness...so light wiping/sanding/steel wool may be necessary.
Kent
Wood Creations by Kent A. Bailey
EXCELLENCE IN SCULPTURE, CARVING, LUTHIER, ARCHITECTURAL MILLWORK AND DESIGN
http://www.kabart.com
PostPosted: Wed Mar 03, 2010 1:47 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
If you mix your own just remember to run it through a filter .
A fine mesh one.
I spray it all the time.
1 liter Alky to 4 oz. of shellac makes a great sealer .
Shake well !
Enjoy! ;)
Mc
Mike Collins
PostPosted: Wed Mar 03, 2010 2:14 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I spray 2 pound cut shellac with the same gun settings as lacquer except the flow needle is closed down a bit as the viscosity is lower. A couple coats and after 24 hours I spray lacquer, I look over the surface and touch up any rough spots with 400 grit but don't sand the whole surface, the gun cleans great with DA. I use a .8 mm tip on a HVLP touchup gun.
Fred
Fred Tellier
PostPosted: Wed Mar 03, 2010 9:57 pm
City: Miami
State: FL
WOW! Great information. This place is the best!!!
Thanks to everyone.
Michael
PostPosted: Thu Mar 04, 2010 11:50 pm
First name: Luc
Last Name: Regnier
Hi Michael,
I also noticed in prior post that one should be careful when spraying shallac
since it is reduced with alcohol which is highly flammable.
Luc
PostPosted: Fri Mar 05, 2010 3:22 am
Last Name: Shaw
City: Philadelphia
LRegnier wrote:
Hi Michael,
Luc
Most spray finishes are highly flammable not just shellac. Don't spray near open flames or even concealed ones like a water heater or furnace.
PostPosted: Fri Mar 05, 2010 9:50 am
I spray waterborne shellac from target Coatings. great stuff. Water clean-up.
PostPosted: Fri Mar 05, 2010 11:03 am
I sprayed Zinnser 100% dewaxed sealer with Preval sprayers for the first time a few weeks ago and was simply delighted. Same thing as using a can, you can't control spray pattern so care is needed during application, but I found it a step up from both wiping and brushing.
PostPosted: Fri Mar 05, 2010 2:01 pm
First name: Richard
Last Name: Sprouse
City: Spartanburg
State: SC
Zip/Postal Code: 29302
Kent
I have always used the Zinsser Sanding Sealer which I believe is a 2# cut but is dewaxed. An I spray it on with no additional cutting
Richard
PostPosted: Fri Mar 05, 2010 2:15 pm
Bailey wrote:
I'm probably going to get the 3rd. degree....but I use (clear) in a spray can from my hardware store. I've used this product on some of my carved wood projects as a sealer coat to a poly finish and used it (reluctantly at first) on my last 3 builds with lacquer and worked just fine. I also liked the convenience of quick coating areas like the top before taping bindings and recoating small resanded areas and not having to mix or clean up my sprayer for small or quick applications.
Kent
Zinsser Bulls Eye "Sanding Sealer" is perfect to spray straight from the can. Their aresol spray shellac is not wax free.
PostPosted: Fri Mar 05, 2010 2:52 pm
First name: Evan
Last Name: McCartney-Melstad
Hi Michael,
My Zinnser spraycan sellac says on the back it is 100% wax free. Is that a lie?
http://www.zinsser.com/pdf/TDB/be_sprshell.pdf
Evan
Evan McCartney
PostPosted: Fri Mar 05, 2010 3:04 pm
evanmelstad wrote:
Hi Michael,
Evan
is the product in a yellow can? or a pinkish? it is possible that Sealcoat comes in a spray can now and I am just not aware but historicly Seal Coat was their only 100% waax free shellac product.
PostPosted: Fri Mar 05, 2010 3:31 pm
First name: Evan
It's in a yellow spraycan, "Traditional Finish & Sealer." Looks just like this:
They claim a "clear, wax-free formula."
Evan McCartney
PostPosted: Fri Mar 05, 2010 5:23 pm
Actually, your can says it is a 100% shellac based formula. It also says it is wax free, but that is not the same as 100% dewaxed, which is a different product. I was informed here that wax is a natural product in shellac. I almost bought the same stuff to use under a waterbase finish, but was told that it isn't the right stuff, and had to go to a store out in the sticks to get the right stuff.
But, if you're spraying laquer and not waterbase it might work fine, but I don't know.
PostPosted: Fri Mar 05, 2010 6:40 pm
First name: Evan
Interesting. The Technical Data Bulletin (http://www.zinsser.com/pdf/TDB/be_sprshell.pdf) says it is 100% wax free. Does that just mean that there is no wax added?
Quote:
Pre-finish Sealer – Spray Shellac is 100% wax-free and
may be used to seal surfaces under polyurethane finishes,
varnishes, paints and other coatings.
I've used it as a light seal coat on one french polished guitar about a year ago and did not run into any problems. YMMV of course.
Evan McCartney
PostPosted: Sat Mar 06, 2010 3:03 am
I can't answer that more definitively, I'm only passing on what I've been told here to help me. I can see why what you have worked under a French Polish though, shellac on shellac would be fine.
PostPosted: Sat Mar 06, 2010 6:21 am
There can't be wax in the spray aerosol shellac as it would clog the nozzle.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Sat Mar 06, 2010 12:34 pm
That is good news to me.
Laurent, do you think the yellow can stuff would work under waterbase finishes?
PostPosted: Sun Mar 07, 2010 10:50 am
The can pictured above does state that the finish is "100% wax-free", and that it can be "topcoated with any interior paint or clear finish". With those statements I have used it under both nitro and under Emtech-6000 and have had no bad results so far. Granted I only started doing this about 2 years ago so only time will truly tell. But as a far as being wax free I would say you are pretty safe.
Kent
Users browsing this forum: johnparchem, Ken Lewis and 17 guests
